double cutting foam for prototype
  • double cutting foam for prototype
    Is it possible to say cut a foam plug for a new design and then cut the back side to specs of a donor car?
    you would cut a inner door jam surround set ,to go from the donor car to the new car body , this way it,s to mount to the donor around the door opening , front engine bay and rear trunk factory mounting areas ,making it easy to mount to the donor car
    front engine bay factory mounting system to use cars original fender mounts
    rear trunk to body kit surround mount
    by doing this way , the kit will be aligned during it first install ,saving time ,and not having to figure out a way to put the body kit onto the donor car,s chassis
        THAT is exactly what i am looking for so i can then take the door off and make the mold of the complete door, etc ...... who can cut foam like this for my design?
          Anyone want to cut some foam ?
