Resins for over foam
  • Resins for over foam
    So this has been something ive been looking for a while. Not sure why it isnt more common to hear people talk about. I needed a hard cap over a foam plug that can be molded or whatever you need it for. Anyother ideas or products you can gladly share.
    https://www.fibreglast.com/product/d...ld-primer-1042
    [url]https://www.facebook.com/RoyalworksSpeedShop/[/url]
    have not tried it. i dont think its any better than epoxy resin. What i find interesting is their polyester resin that doesnt chemically dissolve styrofoam. that gives the possibility of making a part almost directly from a cnc machined styrofoam mold.
      Thats what i hope to acheive. If it can be sprayed out fast enough it could be an amazing part. OR use this for a barrier and then use spies hecker spray poly on top of that if you want to sand or re-CNC the part to perfection. Then you can use the primer they sell and thin it out and use as a sealer. Loctite chemical release and have a perfect mold with all the detail you want without a ton of work.
