what size stock have people used for their stretch? The guy I got the git from gave me 2x3 and 2x4. when I measure the inside of the frame rails I get 1.75x2.25 and 1.75x3.25. does it vary by model year? or is it where I cut the frame (just before the shock tower).
metal stock size for stretch
Re: metal stock size for stretch
Here is a link to an article that shows the typical stretch..
your stretch length may of course be different..
http://www.ifgonline.com/stretch.htmlVisit My KitCarOnLine Blog<br />http://www.kitcaronline.ca and Links Site at http://www.kitcars.ca
For the lower one you can use (2)1 1/2"x2" and cut the pieces about 14" long. This will allow you to put the tubes inside the rail once its cut and helps with getting it strait before you weld. Weld the two pieces together before using them. You can also weld some 3/4" flat bar at the ribs where the origional steel was welded together. I will find a picture to post for you to see it. I find it much easier and safer to do it this way instead of butting the tube in and welding.
http://www.exoticglass1.com/images/chassis%20dim4.JPGwww.exoticglass1.com
