removing console crossmember
  • removing console crossmember
    hello, I am halfway through my flat floor conversion and need to remove part of the crossmember connected to the top of the stock console ( ushaped bar connecting steering wheel to console)should I rebrace this peiec to the forward bulkhead or is it no deal?
    Re:removing console crossmember
    Jerry:
    Re brace the column after removing the center console. There will be nothing to hold up your steering column otherwise. Make it like a street rod and go across the cockpit under the entire dash with a piece of 1 inch square tubing.
