side windows
  • side windows
    I HAVE CHOPPED THE ROOF ON MY 84 ...5 INCHES NOW HAVING TROUBLE WITH GETTING LEXAN OR GLASS MADE ANY HELP
    CHOP TOP
    Re: side windows
    any glass shop should be able to cut it down. id mark it out with tape for them so they know where to cut. They might not want to do it because it wouldnt fit. everyone these days is looking to sue. If you mark it, there off the hook if it dont fit. Id make a paper pattern too to make sure they cut it to your specs. Do one and fit it before doing the other in case you mess up. That way you only replace one window instead of both. If no one will, chk with someone whos already done theirs and see how they handled it.
      Re: side windows
      THANKS I'LL TRY THAT ...OFF TOPIC I JUST RETURNED FROM SPEEDORAMA HTD HAD 3 CARS THERE NOT BAD
      CHOP TOP
        Re: side windows
        How much does admission into Speedorama cost?
          Re: side windows
          RJONES, I always wanted to do a drop top... Can you go into a little detail on how you did yours? 5" is a big drop... How meany degrees did you have to move your winshield back? V8Archie says he moved his his back 9 degrees for his 3" drop. Do you have any pictures? Thanks
          Sorry for all the questions, it's just I like the drop tops and they look cool....
            Re: side windows
            $15.00 ADM...$9.00 PARKING....NOT EXACTLY SURE ON DEGREE BUT WILL CHECK AND I'M WAITING FOR FILM TO COME BACK..WILL TRY TO POST WHEN DOES...MY WIFE SAYS 5 INCHES IS TOO MUCH WHEN I DO AGIAN I'LL TAKE OUT LESS TRY FOR AND GOOD MEDIUM
            CHOP TOP
              Re: side windows
              Looking forward to seeing the pictures...
                Re: side windows
                STILL TRYING TO DO MY SIDE GLASS ..I DON'T KNOW IF I SHOULD TRY TO MAKE A FRAME LIKE A COUNTACH OR TRY TO USE JUST GLASS...ANY SUGGESTION ??? ???
                CHOP TOP
