northstar 5spd????
  • GSXRBOBBY
    Re: northstar 5spd????
    I have everything set up that is needed, and I am about to start making the mounts soon.
  • GSXRBOBBY
    http://www.fierodrivers.com/forum/index.php?topic=765.0
  • GSXRBOBBY
    Archie doesn't do Northstars, I am in the middle of doing one right now. I am using a 93 Northstar and a 5 speed Getrag transaxle from a Fiero. I am having the clutch and a custom flywheel made "5 other guys too", the trans almost bolts up to the motor othe than 1 bolt and the webbing needs to be cut down a little so it matches up. The cradle front cross memeber needs to be cut and replaced 3 to 4 inches up. Other than that the stock axles match up.
    I will be doing a thread when it comes closer.
  • jlestien_dego
    Ive heard that archie does it.
    and it a great kit.
  • viciouscrx
    started a topic northstar 5spd????
    northstar 5spd????
    can you make the northstar a 5 speed and if so where do i get the hardware and tranny?
