Re: Fuel Cell Install Questions
Is there even a bolt-in front fuel cell for the fiero like the front battery tray? If so, any info or pics would be most appreciated.
Brastic,
You may want to try www.summitracing.com
They sell RCI cells as well as straps, foam inserts, and everything else to finish your job. They have an awesome tech line too.
Does anyone know of a "bolt-in" front mounted fuel cell for the fiero? I have seen them before but for the life of me can not now. Thanks in advance for the help.
Here are a couple of links for you.
http://www.jazproducts.com/index2.htm
This link has the mounting straps that you need.
http://www.jazproducts.com/fuelaccess.htm
I used foam, it came in it, I don't feel like I need it.
Hope that helps..
I just bought a fuel cell for my Sterling and now am trying to figure out how to install it.
1. What material of gasket should I use?
2. Should I use foam or not?
3. What metal should I use for strapping it down? Can I get it at Home Depot?
Brastic
