Need to widen Fiero Steering Rack by 2 3/4" Ideas? Sources? Comments?
  • Need to widen Fiero Steering Rack by 2 3/4" Ideas? Sources? Comments?
    hi all
    I have a 308 rebody and am doing a lot of changes to the suspension. The final setup on the front dictates that I need a steering rack that is 2 3/4" longer/wider than stock (85 fiero 4cyl originally).
    Any ideas on the easiest and best way to do this?
    I prefer any setup that uses common (a.k.a. "inexpensive"...) parts (they will be easy to find and replace!) and thus am willing if necessary to rework my steering knuckle to a new taper to fit a different type of ball joint end. However I DON"T want to make custom ball joint ends as they are a replacement/maintenance/wear part...... if at all possible.
    Has anyone experimented with the threads etc to know what other types might fit?
    Thanks for any info!!
    GP
    Re: Need to widen Fiero Steering Rack by 2 3/4" Ideas? Sources? Comments?
    im not 100 percent sure but i think all you will have to do,is use an 88 model tie rod end and retain the fiero rack,again im not positive.
      I used a custom made tube to add to the tie rod end.  It has been on my car since 1998.  Here it is installed on FunnyWheels I after 35,000 mile of use. Photo was sometime in 2000.
          The 88 inner tie rod is 1 3/4" longer then the 84-87 inner tie rod. Other than that it is the same and will bolt up the same. The extra lenght is in the shaft between the threaded end and the ball socket. I have 88 inner tie rods on my web page. www.rodneydickman.com.
            ok i wasnt totally wrong,i knew that i had read somewhere before that the 88 stuff was longer ,i thought it was in the outer tie rod,oh well
              darn
              sorry Rodney; by the time I got that I had already found a 'close' part and taken it for machining. Actually I just called the place back today when I saw this and he said he didn't have a listing for that part anyway. But it will go into my 'maintenance' manual for the car along with what I am using altho these require a bit of machining at the base.....
              But good to know for the future.
              thanks!!
              gp
                nice!
                This article is clear and easy to understand. I'm learning more about this. Hope you bring more things related to it. Thanks a lot!
                lenny face
                [URL="http://hotmailsignin-login.com/"]www.hotmail.com[/URL]
                  this is amazing!
                  This is a great article, that I really enjoyed reading. Thanks for sharing. - kerala lottery resultslenny faceStatus n Quotes
                    Sunsets,
                    Sunrises,
                    Living the dream, watching the leaves, changing the seasons
                    Some nights
                    I think of you
                    Reliving the past, wishing it’d last, wishing and dreaming
                    I know that birds fly in different directions
                    I hope to see you again. yeah so hope.
                    emoji
                      Need to widen Fiero Steering Rack by 2 3/4" Ideas Sources Comments
                      I prefer the standard rack on the 155, but if you reall want one to get the experience as Alfa intended youll also need the suspension uprights as the angle of the angle and length of the arm the track rod end bolts to is different.
